Surface Pro microSD card unmounts after waking up from sleep
2013-03-01T00:26:48+00:00
I've recently bought Surface Pro along with a 64 GB sd card. I've noticed that after a long sleep period, the SD card unmounts itself and I can no longer find it under explorer. I need to remove and reinsert it before Windows detects the card again. This doesn't happen if I wake up the device shortly after putting it to sleep, only after a few hours. I wouldn't mind it as much if I didn't have to set up Skydrive again after reinserting. I think it might have something to do with s3 sleep, and might be a driver/software error, but I'm not entirely sure. Any ideas?
2014-07-22T16:48:29+00:00
I finally solved this problem by enabled write-caching for the SD card.  My card no longer unmounts unexpectedly when changing power modes.  I realize this comes with some risk of possible data loss if the card is not ejected properly.
  1. I right-clicked on the SD card device in device manager under Disk Drives.
  2. Then clicked properties
  3. Then went to the policies tab
  4. And then selected "best performance"
So far, no unexpected dismounts and no data corruption.  This has also improved the performance of the device as reads and writes of large files seem to be much smoother now.
My theory is that this setting is preventing the slot from powering down while in a hibernated or suspended state.
2014-02-06T04:56:51+00:00
Hello Ted
Check out my other post here
http://answers.microsoft.com/en-us/surface/forum/surfpro2-surfdevice/micro-sd-slot-no-longer-recognized-in-the-surface/2705d99f-440a-41a4-9bdf-965f1b092efd
Eventually I changed the card same make/ model, formatted it as NTFS and so far have had no issues at all...........and its been almost 2 months now.
I think Scandisk have issues with quality control ?
Try a full format on NTFS , it does take sometime
If it still has issues after that I would use the card in your phone or something else and by another one brand new for the slate.
It worked for me.
I guess we will get the same issues when the 128GB MSD card comes out!
Good luck
2015-07-17T20:46:00+00:00
Simply change the driver to generic USB mass storage.
78 additional answers
    2016-12-23T20:38:25+00:00
    I have the same issue, and seem to have come across the fix.
    When my micro SD card stopped working / randomly unmounted, I checked Device Manager. In Device Manager under Storage Controllers, the SD Storage Class Controller for the SD slot was disabled.
    What is happening, I think, is the system is putting the SD slot to sleep to save power (whenever it feels like it).
    To fix, in Device Manager (right click or long touch on Windows logo in bottom left of screen, choose "Device Manager"):
    • Scroll to bottom and expand "Universal Serial Bus Controllers" (USB)
    • Open property page for "USB Root Hub" (or similar). You can open by double clicking or long touch and choose 'properties'.
    • On the "Power Management" tab, uncheck "Allow the computer to turn off this device to save power". Click ok.
    • Close Device Manager.
    • Hopefully this fixes it
    I am testing on my device now...so any confirmation that this works, please share.
    This didn't work for me.
    I did something that is not a fix but makes it less of an annoyance.
    I turned off what windows 10 does when you insert a new micro sd card.
    In setting under "Devices" >Auto play >Removable drive set it to "Take no action".
    Memory Card set it to "Take no action"
    I also turned of both the sound when you insert a new card and the sound when you remove a card.
    I still get a can't write error occasionally but by the time you save again the drive is already awake.
    No more explorer windows popping up, no more mounting and dismounting sounds but like I said, not an annoyance but NOT a fix.
    I'm really tired of this problem and I've tried just about everything. Including turning of the option to let the drive go to sleep.
    cheers,
    james-
    2016-12-23T23:59:57+00:00
