Surface Pro microSD card unmounts after waking up from sleep
2013-03-01T00:26:48+00:00
I've recently bought Surface Pro along with a 64 GB sd card. I've noticed that after a long sleep period, the SD card unmounts itself and I can no longer find it under explorer. I need to remove and reinsert it before Windows detects the card again. This doesn't happen if I wake up the device shortly after putting it to sleep, only after a few hours. I wouldn't mind it as much if I didn't have to set up Skydrive again after reinserting. I think it might have something to do with s3 sleep, and might be a driver/software error, but I'm not entirely sure. Any ideas?
2014-07-22T16:48:29+00:00
I finally solved this problem by enabled write-caching for the SD card.  My card no longer unmounts unexpectedly when changing power modes.  I realize this comes with some risk of possible data loss if the card is not ejected properly.
  1. I right-clicked on the SD card device in device manager under Disk Drives.
  2. Then clicked properties
  3. Then went to the policies tab
  4. And then selected "best performance"
So far, no unexpected dismounts and no data corruption.  This has also improved the performance of the device as reads and writes of large files seem to be much smoother now.
My theory is that this setting is preventing the slot from powering down while in a hibernated or suspended state.
2014-02-06T04:56:51+00:00
Hello Ted
Check out my other post here
http://answers.microsoft.com/en-us/surface/forum/surfpro2-surfdevice/micro-sd-slot-no-longer-recognized-in-the-surface/2705d99f-440a-41a4-9bdf-965f1b092efd
Eventually I changed the card same make/ model, formatted it as NTFS and so far have had no issues at all...........and its been almost 2 months now.
I think Scandisk have issues with quality control ?
Try a full format on NTFS , it does take sometime
If it still has issues after that I would use the card in your phone or something else and by another one brand new for the slate.
It worked for me.
I guess we will get the same issues when the 128GB MSD card comes out!
Good luck
2015-07-17T20:46:00+00:00
Simply change the driver to generic USB mass storage.
78 additional answers
    2015-02-24T22:05:46+00:00
    By way of an update, it has been 5 months since MS replaced my Surface Pro 2, and even though I am using the same SANDisk 128GB MicroSD card (along with occasional use of others), it has not unmounted on me even once. I have a high degree of confidence my problem was specific to a hardware issue with the MicroSD reader, or some other hardware related issue. Refreshing the install did nothing to help, replacing the hardware cleared it up 100%.
    i have noticed that when it wakes up the MicroSD icon takes a moment to appear, but it has yet to fail to unmount on the replacement unit (or fail to automatically remount after bring asleep, whichever is the technically correct way to look at it.)
     ”MicroSD icon takes a moment to appear“ means "unmount and mount" that is remount. So, your issue persists only being alleviated.
    I have a SurfacePro 1 and same issue.  After a few attempts to complain and software update, MS replaced my SurfacePro.  Since then, I never had the unmounting issue.  Agree that it's very likely to be hardware issue.
    2015-02-24T22:28:46+00:00
    Mine is Surface 2 with Type Cover 2. The distinctiveness from the "Pro" line of Surface is that - SD Card get lost *only* when waking up by uncovering the type cover 2.
    There is a dedicated thread for Surface 2 with Type Cover 2 - http://answers.microsoft.com/en-us/surface/forum/surf2-surfhardware/surface-2-microsd-card-ejects-when-waking/c6d716c9-c1cb-4a93-a0ca-14c2581f5446
