Strange -- suddenly today after going almost a month, the CPU throttling issue happened again for me today. Guess I'm back to using ThrottleStop again to workaround it.
Surface Pro 6 Runs Slower in Dock
My Surface Pro 6 runs noticeably slower when it is connected to the dock. I have a dock at both home and work and see the same reduced performance in both places. This is not a new issue (unlikely related to a recent Win or other software update). Both docks were originally purchased for use with my previous Surface Pro 4 device.
Does anyone else notice such a pattern?
Any thoughts on what might be causing this and how to fix it?
- Surface Pro 6, i7, 16gb
- Win 10 10.0.17763 Build 17763
- >300GB of 500GB hard drive are free
I don't see any obvious issues when looking at Task Manager. CPU, memory and internet are all lightly utilized.
Thanks much for any thoughts.
-bs
2019-11-13T20:34:58+00:00 -
2019-11-13T20:43:16+00:00 I haven't had the problem since 10/6. There were some updates applied at that time - so, knock on wood, maybe it was fixed?
2019-11-15T13:54:33+00:00 It was fixed for a month for me and now is back again
2019-11-15T19:07:12+00:00 After the incident the other day, I completely shutdown my Surface at the end of my work day and left it powered off over night. Since then I have had no issue -- I used it docked all day yesterday at work, and so far so good today.
