Surface Pro 6 Runs Slower in Dock
2019-04-09T02:47:14+00:00
My Surface Pro 6 runs noticeably slower when it is connected to the dock. I have a dock at both home and work and see the same reduced performance in both places. This is not a new issue (unlikely related to a recent Win or other software update). Both docks were originally purchased for use with my previous Surface Pro 4 device.
Does anyone else notice such a pattern?
Any thoughts on what might be causing this and how to fix it?
  • Surface Pro 6, i7, 16gb
  • Win 10 10.0.17763 Build 17763
  • >300GB of 500GB hard drive are free
I don't see any obvious issues when looking at Task Manager. CPU, memory and internet are all lightly utilized.
Thanks much for any thoughts.
-bs
    2019-04-12T10:02:59+00:00
    this has just happened to me.  worrks ok until you dock it.
    2019-04-12T14:37:26+00:00
    I am hoping this is fixed now. I called Microsoft and they did three things (only one that was new):
    1. Ran the Surface Toolkit. I'm not sure that this task did anything but it's probably a good idea.
    2. Follow these instructions to install and then run the Surface Dock Updater. The first time I ran this installer, it failed. The program told me to power cycle the unit and do it again. It worked the second time. I am guessing that the update to the dock's firmware was the item that had the most impact. I was unaware of this tool.
    3. Installed the latest firmware and drivers for my Windows Build 17763 using this link. Presumably I should not have needed to do this since Windows Update should be keeping these current. The MS tech, however, stated that it was important.
    Hope this helps others.
    -bs
    2019-04-13T20:42:04+00:00
    I'm having exactly the same problem. My Surface Pro 6 is significantly slower when connected to the Surface Dock. But I already have the latest Surface Dock firmware installed (2.23.139.0) since a long time. My Windows version is 17763.437.
    @Moirty I wish you best, but I'm afraid that updating the Surface Dock firmware is not (yet) a solution.
    Any further ideas?
    2019-04-27T19:37:31+00:00
    So what? Now nobody cares?
    2019-04-28T01:34:57+00:00
    I've been playing with a variety of configurations with and without the dock attached. I notice that I never have problems when I boot without and don't use the dock. However, there are times when I have no problems while using the dock initially and then find that the performance degrades with time. I've tried plugging the monitor and my other USB accessories (keyboard and mouse) directly into the computer. This seems to work better at least for a while but nothing is conclusive.
    It does not seem to be a very reliable configuration.
    -bs
