Do the new surface firmware and/or dock firmware appear to resolve the CPU throttling issue with the surface on the dock?
Surface Pro 6 Runs Slower in Dock
My Surface Pro 6 runs noticeably slower when it is connected to the dock. I have a dock at both home and work and see the same reduced performance in both places. This is not a new issue (unlikely related to a recent Win or other software update). Both docks were originally purchased for use with my previous Surface Pro 4 device.
Does anyone else notice such a pattern?
Any thoughts on what might be causing this and how to fix it?
- Surface Pro 6, i7, 16gb
- Win 10 10.0.17763 Build 17763
- >300GB of 500GB hard drive are free
I don't see any obvious issues when looking at Task Manager. CPU, memory and internet are all lightly utilized.
Thanks much for any thoughts.
-bs
2019-09-19T02:24:47+00:00 -
2019-09-19T06:09:11+00:00 No idea yet. I just installed it few hours ago so it's too early to judge.
2019-09-22T08:57:27+00:00 New Surface Firmware update - 241.1.139.0 DOES NOT solve 0,4 GHz throttling issue.
I can't believe this. Can't believe this.
Deleted
2019-09-23T16:05:14+00:00 I tried putting a fan over the dock and then over the cable insertion on the SP6 (didn't have two fans, just tried one at a time), and found no difference. The Surface Pro 6 would still slow its CPU down to 0.4 as soon as the docking station was plugged in.
However, I have had some success thus far after changing the "power mode" to "best performance" (without using any fans). This is found by left-clicking on the battery icon by the clock on the taskbar.
Not ideal, I realize, but after setting this, I have not yet had the CPU throttle back down.
Can anyone else confirm whether or not this works for them with their setup?
Ari
BOOM! This is the best tip yet!
I did this, and went from 0.4 to 3.8 instantly. So far, holding steady after an hour.
BTW, I have had the slow-down issue with a regular Surface charger cable (not dock) as well.
Thank you for this super simple solution -- at least for me -- at least for now..... fingers crossed.
