On-screen keyboard does not display in tablet mode - Surface Pro
2013-02-13T07:57:49+00:00
I am having trouble getting the onscreen keyboard to display when my Surface Pro is not connected to its type cover.
I noticed this when I was in the Metro UI.  The issue occurs when I select the search option from the charms menu.  Once I do this, the onscreen keyboard does not appear, so, I am unable to type anything into the search box.
This also occurs when I attempt to access the Surface Pro from sleep mode.  The password box appears, but, I cannot input into it without the onscreen keyboard.
I have already tried the refresh option - it did not work.
Any thoughts on a fix for this issue?
2016-09-19T15:45:17+00:00
Hi. I had the same problem and it was really bugging me but I finally got it sorted. Basically, while your in laptop mode press the little keyboard icon (at the bottom right of the screen where the time is) and the on-screen keyboard should come up. Without pressing 'x' on the on-screen keyboard, un-clip your real keyboard so it turns into tablet mode. Now you can press 'x' and go onto the internet or something to test out whether it worked or not. Press on the search bar and it should come up. I had to do it twice but it worked. Hope this helped someone.
2013-02-13T09:11:34+00:00
when waking it from sleep, only remove the keyboard when the lockscreen is displayed. Thus is also a bug with the surface rt when waking from connected standby.
50 additional answers
    2013-02-17T05:19:42+00:00
    hi everyone, I had this problem too and a refresh seems to have fixed it. must be a software problem.  hopefully Microsoft is listening and will fix it.  This really ruins the usability of the tablet
    2013-02-19T19:46:31+00:00
    I just experienced this same behavior and the chat support Karen P was able to help me resolve it. Copying from chat script what resolved this issue for me.
    The first I would like you to do is to remove the keyboard, lay it flat on a table or other flat surface and then hover your Surface Pro just above where it connects until the keyboard "jumps up" to connect.
    Karen P: I would like you to repeat this action 15 times. This will work the connection as well as unload and re-load the drivers.
    Karen P: Once you have completed this action, can you please restart your Surface and let me know if it still responds as it has been
    2013-02-19T19:49:34+00:00
