On-screen keyboard does not display in tablet mode - Surface Pro
2013-02-13T07:57:49+00:00
I am having trouble getting the onscreen keyboard to display when my Surface Pro is not connected to its type cover.
I noticed this when I was in the Metro UI.  The issue occurs when I select the search option from the charms menu.  Once I do this, the onscreen keyboard does not appear, so, I am unable to type anything into the search box.
This also occurs when I attempt to access the Surface Pro from sleep mode.  The password box appears, but, I cannot input into it without the onscreen keyboard.
I have already tried the refresh option - it did not work.
Any thoughts on a fix for this issue?
2016-09-19T15:45:17+00:00
Hi. I had the same problem and it was really bugging me but I finally got it sorted. Basically, while your in laptop mode press the little keyboard icon (at the bottom right of the screen where the time is) and the on-screen keyboard should come up. Without pressing 'x' on the on-screen keyboard, un-clip your real keyboard so it turns into tablet mode. Now you can press 'x' and go onto the internet or something to test out whether it worked or not. Press on the search bar and it should come up. I had to do it twice but it worked. Hope this helped someone.
2013-02-13T09:11:34+00:00
when waking it from sleep, only remove the keyboard when the lockscreen is displayed. Thus is also a bug with the surface rt when waking from connected standby.
50 additional answers
    2013-03-08T07:56:27+00:00
    Well hang on now, there could be a built-in reset that is signaled by this action.
    2013-03-08T19:43:08+00:00
    This should be the new Surface pro commercial....bunch of geeks sitting around the table and attaching and detaching touch covers. My Surface Pro lasted almost 3 days....Touch pad didn't work, on screen keyboard didn't work unless I had to manually get it out. I spent long time with a tech trying out everything with and without the touch pad.....refresh...factory reset...attach and detach....didn't do any break dancing...
    I packed it up and returned for a refund.
    2013-03-08T19:56:05+00:00
    Most of those geeks would actually be on this forum I would think. ;)
    I really like my Surface Pro but I did not break dance when I began using it either. I have yet to have the keyboard issue so far. There seems to be a bad build image floating around amongst the Surface Pros that were initially sold possibly. Did you not want to try an exchange?
