I am running Win 10 Pro, Version 1511 OS Build 10586.104 and have the exact same problem following Feb 17 update.
2/17 firmware update installed, but when I look in Device Manager in the firmware section, I get Code 10
Split from this thread.
You may THINK that you have the updates installed but you may NOT:
BUT:
I tried reboots, re-installs, and everything else, but the updates fail to start.
2016-02-20T15:08:15+00:00 -
Deleted
2016-02-21T04:52:17+00:00 I downloaded the latest .msi (SurfaceBook_Win10_160400_2.msi) from the microsoft site.
After the download completes you get a corrupted signature error and you are prompted to delete the file (you might want to fix this).
I did not delete the file and instead installed it (bypassing warnings from the OS as the signature is bad). It installed successfully and I rebooted. However this did not resolve the problem. In device manager for all the new firmware updates I still get:
"This device cannot start. (Code 10)
Indicates a revision number encountered or specified is not one known by the service. It may be a more recent revision than the service is aware of."
2016-02-21T06:50:51+00:00 What is the firmware version shown in the boot-up BIOS screen?
Can you please write it down or take a photo?
2016-02-21T10:46:18+00:00 Here is what firmware is showing up in the bios boot screen:
UEFI: 88.870.770
SAM: 88.853.258
ME: 11.0.0.1183
EC: 88.855.257
Touch: 151.45.94.4.26
In Device Manager I show the latest drivers (UEFI 88.1085.768.0) but with error:
