2/17 firmware update installed, but when I look in Device Manager in the firmware section, I get Code 10
2016-02-20T02:36:42+00:00
Split from this thread.
You may THINK that you have the updates installed but you may NOT:
BUT:
I tried reboots, re-installs, and everything else, but the updates fail to start.
    2016-02-25T16:31:40+00:00
    Well I have neither Firmware resource last attempt status nor Firmware resource last attempt versionin the Details drop down in any of the firmware listed with Code 10 in my system.
    However for the UEFI I have Firmware resource version: 160D9B02, Firmware resource lowest supported version: 15CC6500. Has Problem: true.
    Status: 01802400
    DN_HAS_PROBLEM
    DN_DISABLEABLE
    DN_NT_ENUMERATOR
    DN_NT_DRIVER
    2016-02-24T19:46:20+00:00
    ReSurfaceMan and others with the Code 10 in Device Manager for the Surface Firmware components, can you let me know some more details. For each item with a Code 10 error, double-click it to open Properties and then from the Details tab, select the "Firmware Last Attempt Status” and the “Firmware Last Attempt Version” properties from the drop down and let me know the corresponding values.
    Greg
    Surface Management Engine
    Firmware resource last attempt status:
    NA
    Firmware resource last attempt version:
    NA
    Surface System Aggregator Firmware
    Indicates a revision number encountered or specified is not one known by the service. It may be a more recent revision than the service is aware of.
    C0000058
    1610E501
    Surface UEFI
    C0000058
    1610F700
