My apologies. The 319.99 OOW exchange is for a Surface RT.
It is $469.99 for OOW exchange dealing with a Surface PRO.
After 3-4 years, you will need to pay the OOW cost if you do need to exchange it for any reason.
Does anyone know how much Microsoft charges to replace the battery in the Surface/Pro?
I just bought a Pro model with the extended warranty, but would really like to know. I can't seem to find anything about it thus far. Because, eventually the battery will go bad, as do all batteries.
Apple has a policy where you ship them your old iPad with the bad battery, pay a flat fee, and they ship you back a refurbished iPad.
Does Microsoft do the same thing? I would imagine it would be a swap out for a refurbished model, because of the difficulty repairing the thing.
And then OMG, what happens if you have Office 2013 on your Surface? Will the replacement one have it installed and functioning under your old license key, or do you need to buy a whole new license to reinstall on the refurbished Surface?
Any help would be much appreciated! Thanks!
Greetings Hyperlexis,
These are great questions to ask our Technical Support Team as they will be able to give you an answer. If you would like to post back what they tell you, that would be great to share with the community. You can reach our Technical Support Team here:
The battery is not user replaceable.
Barb
Windows Experience MVP
Hi all,
There are no user serviceable parts inside Surface. Opening the case will void your warranty. Please contact our support for battery related concerns.
Regards,
Clare
No, none of the Surface devices have a removable battery.
I've watched a video on taking the Surface apart and it's certainly not for the faint of heart.
Hope this helps.
Hello and G'day again ShirishGandhi,
The manufacturer warranty is 1 year in which you can have your device repaired or replaced for an unlimited amount of times. Once the device is replaced, the warranty will continue until the end of its time period or have an additional 90 days. Which ever one is longer. Meaning, if you are near the end of your warranty, the 90 day time period will be added.
From the date of purchase, you will have 90 days of Tech support.
From the date of purchase, you will have 45 days to purchase the Microsoft Complete warranty giving you a total of 2 years Tech support, Accidental damage with a 50 dollar deductible, 2 years of hardware warranty.
Anything outside these time frames will be considered a Out Of Warranty exchange. The cost for a OOW exchange for a tablet is 319.99
When you send a Surface tablet for battery replace, Microsoft simply replaces the tablet. They do not replace the batteries.
The Surface tablets have the lowest repair rating compared to all other tablets and even though the battery packs are replaceable, you just plain can't get to them without destroying the screen. It is even worse with the Pro 3 because it has thinner glass and the glass fractures when any attempt is made to remove the screen.
The iPad/iPhone/iPods are designed to be fairly easy to disassemble and to replace the batteries. Not for a novice, though.
The iPad Pro will be something but it is built quite like the iPad Air and there will be no access panel in place to replace the battery packs. That will still have to be done in a shop. However, it will be fairly easy to replace the battery packs.
Office for iPad is good but only about 30% of that as the Office installed on the RT models and available for the Pro models. I have it myself and it works good but missing a whole lot of features. That will be the only version of Office available for the iPad.
The Surface tablets are just plain not designed for internal maintenance.
If you want full details of servicing the Surface tablets (all models to include the new Pro 3), go to http://www.ifixit.com (they also have an app in the Store as well) and see for yourself.
