2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-01T19:56:50+00:00
    Ben,
    We all have all of the the latest updates installed, that is clearly not the issue. Any word on fixes for either the constantly crashing display driver, as noted by rp1010, or the lack of a sleep mode? We're trying to determine if we need to return these devices or if Microsoft will have a fix.
    2015-11-01T20:39:53+00:00
    grvak,
    Thanks for your query. Please check your Windows update history and make sure that you have the latest update. While checking look for:  “Surface Hardware Update – 10/23/2015”.
    If you do not see it, please run updates manuallyand once done, manually restart your Surface and let us know the outcome.
    Hi Ben,
    I dont see the system firmware update - 10/23/2015 in my update installed history. However, windows auto update states all updates available are installed, and I cant find surface pro 4 update from the mannual method you and microsoft provided.
