2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-01T16:13:23+00:00
    Same problem here, has anyone also noticed unusual battery drain when this system is in standby? I sometimes notice the unit is warm when I pick it up after its been on standby indicating that its running some process while off and draining the battery.
    It's been reported by quite a few people -- supposedly, it's also part of the display driver fixes that need to be implemented.
    In the meantime, changing power button functions from "sleep" to "hibernate" seems to work (though obviously starting the computer back up takes longer).
  2. Deleted
