2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-01T13:25:54+00:00
    I am having the same issue. I attempted to download the driver directly from Intel but it would not allow me to install.
    2015-11-01T15:27:37+00:00
    Same problem here, has anyone also noticed unusual battery drain when this system is in standby? I sometimes notice the unit is warm when I pick it up after its been on standby indicating that its running some process while off and draining the battery.
