2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-10-31T19:09:22+00:00
    I'm having the same issue. The display driver crash happens multiple times per day.
    I have all the latest updates.
    Using Skype seems to make the problem much more prevalent.
    2015-11-01T01:51:06+00:00
    Have had this issue at least 15 times in 3 days with my Surface Pro 4.
