2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-03-18T12:50:05+00:00
    All updates installed but screen still freezes every few minutes when browsing the internet. Super frustrating!!
    2016-03-18T15:55:47+00:00
    The intel download requires that I uninstall the Microsoft Video Driver first which would leave without a way to install a new driver because I would no longer have an interface with the computer.
    I have a lot more problems while using Microsoft Edge than other browsers.  If I use Edge, the Pro 4 gets really hot and it crashes everyday.  If I don't, it will go several days without crashing.  Thinking about going back to my Lenovo Yoga which would go months between crashes.
