2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-03-14T19:52:10+00:00
    Surface Pro 4 i7 / 16 Gb Memory / 512 Gb SSD
    Every time I open the Edge browser on my Surface and there is a video embedded in the page, the entire screen starts flickering and in some cases crashes the display driver. Most of the time, the screen flickers and I am forced to close the Edge browser. It happens all the time. I was forced to install Chrome as Edge is unusable.
    I have ALL updates installed.
    I saw another post where this issue was fixed in the Feb 17 update but I have that update installed and it still happens. Very annoying.
    2016-03-15T21:27:38+00:00
    Even after the update, still get the display driver error and most times the screen freezes and I have to do a hard reboot.  Update helped with the heat crashes I was getting, but it still runs too hot to use as a tablet.  This is on a Surface 4 Pro I7 1TB.
