2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-03-04T00:28:22+00:00
    Thank you Paulo!
    I managed to execute the steps. I installed the .msi file and found no warning signs in the device manager. Then I ran the commands as you described, found an error with the sfc, after that downloaded the iso and followed the instructions, however i did not find any memory dump files. Until know the problem has not appeared. I let you know if the video adapter driver stops again, while using Edge and Eclipse (Developing Python code).
    Thank you again for your time!
    2016-03-09T22:39:18+00:00
    Hello Paulo!
    Time passed, I really did not use eclipse for a while, but I started writing again Python code on my Surface Pro 4. I am using Eclipse Mars 4.5.2 and Java with version of 8 update 73, and Python 3.4 interpreter. The problem came again, system freezed for a few seconds went black, then the screen reappeared. The RAM usage is approximately 70%. The problem comes randomly. Simply, I just want to write some lines of code, and I can not type for a while and everything freezes.
    Do you have any idea what is the problem? How this issue can be fixed?
    Thanks for your help!
