2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-03-03T18:42:20+00:00
    Hello Microsoft Community!
    I have a Surface Pro 4, every updates installed. Today I have installed some updates too, called Cumulative Update for Windows 10 Version 1511 for x64-based Systems (KB3140743) and Update for Windows 10 Version 1511 for x64-based Systems (KB3139907). After some time my Surface's screen went black (while using Edge browser and editing some code with Eclipse), a bit freezed, than came back to life, and gave a notification that says Intel HD Driver for Surface has stopped responding, now succesfully recovered. Moreover my Surface has to be force restarted, because it freezed, and sound just stuck. This problem today appears very often.
    Is it a known issue with this new update? When MS will fix this? Or what can I do to prevent this kind of failure? Is this problem can be connected with visual c++ redistibutable or directx update/install?
    Thanks in advance!
    2016-03-03T20:37:46+00:00
    That is odd. There are several steps that you could perform to troubleshoot these issues.
    1. Download the file SurfacePro4_Win10_160401_1.msi from here and install it. It will reboot your computer to update firmwares and so on and once it is finished and you're back on your desktop, do another reboot.
    2. Open Device Manager (right click the Start button and select Device Manager) and check that there are no warning signs on any device. It should look something like this:
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=4fb78ca5-cd16-4f2d-8309-ce08b8c5207c)
    Any node in the tree above that is expanded by default with a device item below it that has a yellow warning triangle on its icon is a problem. The MSI above is supposed to have the whole package of drivers for the SP4. 3. Open an admin command prompt (right-click the Start button and select Command Prompt (Admin)) and run the following command:
    sfc /scannow 4. If the utility above finds any problems that it cannot fix, follow the steps detailed in this thread to attempt to fix them. 5. Check whether you have a MEMORY.DMP file on your C:\Windows folder and what the date is. If it is a recent file (i.e. a couple of days old) try to compress it (right click file -> Send to -> Compressed (zipped) folder) and upload it somewhere public (i.e. Dropbox, OneDrive, GDrive, etc.). Post a link to it here and I will take a further look.
    I hope the steps above are helpful. Let me know if you have any questions.
