2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-03-02T19:49:21+00:00
    Still problems.
    The biggest problem that I have now is when I connect to the docking station with a 1080p second adapter. The computer knows that there is a second adapter, but it cannot extend the desktop.
    Found a temporary workaround (it is ugly).
    1. Go to "Device Manager",
    2. expand "Display adapters",
    3. Right click on "Intel HD Graphics 520"
    4. Click "Disable" and accept with "Yes"
    5. The Surface screen will flicker and get back to normal
    6. Right click on "Intel HD Graphics 520" again
    7. Click "Enable"
    The docking station and the remote monitor now works.
    This leads me to believe that the Display adapter driver is stopping and restarting, causing it to resolve the issue. It looks like it is still a display adapter driver issue. I originally though the issue was the docking station, but this seems to indicate that it is a display adapter driver issue.
    My gut feeling is that the problem is caused by incorrect handling of "sleep" by the display adapter. Using Hibernate instead of sleep seems to work better than just sleeping.
    I sure hope that Microsoft and Intel have people that are monitoring this thread. They need to fix this now.
    Niels
    2016-03-02T20:20:53+00:00
    Niels:
    I think your onto something associated with the sleep function.  I'm going to shut all that functionality off and see if it improves anything.   Although I do use a surface 4 dock , I am not using a second or auxiliary display of any kind. Just the Surface display itself.  The display adapter driver is definitely stopping and restarting, I have just never timed it before to see if it is related to the sleep/hibernate timers.
    Kind of embarrassing for the Intel/Microsoft team after all this time not getting to the bottom of this.
    Larry
