2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-24T09:42:51+00:00
    after a few days a problem with the display driver returned :-(
    2016-02-29T00:13:17+00:00
    Hi josh:
    Still getting crashes.  Perhaps even a slight increase in crashes.  Checked and see the dated update you referred to.  My take is that this did not correct the problem.
