2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-23T21:21:34+00:00
    The latest 2/17/16 update crashed my Surface Pro 4.  There is now a yellow band across the top of the screen at startup and the touch screen and pen no longer work.  All suggested remedies have been tried, including reinstalling windows.
    2016-02-23T21:59:24+00:00
    If reinstalling windows didn't help it sounds like the firmware failed to install correctly.  Though I have never tried to reinstall firmware on the sp4 I suggest you give it a try before returning the sp4 to MS for replacement.  Best choice, go to a MS retail store  if one is available to you.  Latest 2/17 update software and firmware download available HERE!
