2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-20T17:07:28+00:00
    Mine crashed 2 times after update.  on Microsoft's own web site.  Nice.
    2016-02-20T17:13:07+00:00
    Hi All,
    Josh
    And since you released the update I started getting the display driver error again, after weeks of not getting it.  AND, my computer just locked up.  I had to hold down the power button for 30 seconds to wake it up again.
    Thanks for making my life **** MS.
    Steve
