2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-20T12:54:54+00:00
    Well we have two Surface Pro 4 devices with the i7 and Iris 540 Graphics and the latest driver from Microsoft (4364) is better but has still repeatedly crashed when using the Microsoft Video Renderer, however....the Beta driver from Intel (4380) has a specific fix for this stated in the release notes and having installed that on one device - no more issues for two days now doing the same sorts of things, so there is hope, but not it seems from Microsoft...shame on you....
    Not to mention all the other issues that I constantly have to "workaround"
    2016-02-20T13:22:04+00:00
    For me, after updating everything is stable (SP4 Intel 5), but it may also issue some additional soft, once a long time ago when I used yet SP2 had similar problems after the installation of the virtual desktops tool . My list of applications: Office 2013, VLC, TeamViever, Paint.net, WinSCP, UltraVNC, Skype, Nmap, WHireshark, Netscan, , any codec, any other browsers than IE and EDGE
