2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-20T04:23:26+00:00
    Yes , so I am
    2016-02-20T12:46:18+00:00
    Two Days after the update. 17.02.2016  , everything is stable on Display Driver but the
    Onscreen Keyboard hangs sometimes in foreground and don't blank out.
    Only help was a restart.
