2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-19T13:48:40+00:00
    Two days after the update. 17.02.2016 Any problems, everything is stable, connect an external monitor, work on Edge with multiple tabs, touch, pen, paint.net for me SP4 now works very well.
    During the upgrade were two restarts (including 7 upgrade in the history)
    2016-02-19T18:05:19+00:00
    since my surface has been updated, I have to shutdown by holding power key if i face a problem during sleep mode .
