2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-19T06:14:46+00:00
    I don't see it happen in other app yet.
    It happen in FB 4.7 these two days.
    once per hours.
    2016-02-19T09:19:49+00:00
    To troubleshoot the “display driver stopped responding and has recovered” error, you could update and/or re-install the Display adapter’s driver.
    1.       Go to Device manager (type device manager on the search screen)
    2.       In device manager select Display adapter
    3.       Select **** then Intel(R) HD Graphics
    4.       In properties select the tab Driver
    5.       Click update driver
    6.       Select Search automatically for update driver software
    7.       Click ok
    8.       If this does not fix the issue repeat steps 1 to 4
    9.       Click Uninstall (please do not tick any boxes)
    10.   Click ok.
    11.   Select Yes on “Do you want to restart your computer now”
