2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-19T00:17:54+00:00
    Does this only happen using Flash Builder?  What version of FB are u using?
    2016-02-19T04:18:34+00:00
    For the past few weeks my Surface Pro 4 had been pretty stable...  Very few graphics driver crashes.  Not 10 minutes after I installed the latest updates (2/17) the GRAPHICS DRIVER CRASHED TWICE.  Why can't Microsoft ever get anything right??  This update has apparently made the issue worse. Anybody who's Surface is working well DO NOT install the most recent updates.
    I had the same problem, the driver crashed shortly after I did an update.  However, after I decided to do a restart, I noticed that it said that the installation was still not complete.  After one more restart it appeared that everything got installed and I have not had a driver crash.   I hope that you computer just needs a restart or two as well.
