2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-18T22:56:50+00:00
    Guys this look like the real deal, no crashes and better battery life, very happy!!
    2016-02-18T23:32:42+00:00
    It come out while I using FlashBuilder to type.
