2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-18T21:17:40+00:00
    Hi action03
    More than one restart (not shutdown) may be needed to successfully install updates.
    1. Go to Start, and select Settings > Update & security > Windows Update.
    2. Select Advanced options, and select View your update history.
    3. If any update has a status of “Requires a restart to finish installing”, restart (don't shut down) your Surface.
    4. Go back to Step 1 and repeat until no update has a status of “Requires a restart to finish installing.”
    Example of update history where updates have status of "Requires restart to finish installing:
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=aff67313-8983-42cd-8ae0-faa13b9e0b1d)
    Please let us know your experience after confirming no updates require a restart to finish installing.
    Josh
    2016-02-18T21:36:08+00:00
    All four updates for 2-17-2016 were successfully installed.   No issues with the install process.  No additional restarts required and no problems since the updates.   I performed the Excel and Edge functions that were giving me failures.
    Have one of the first day SP4s shipped by Microsoft.
    Still have Edge issues when printing outlook.com email as it does not always fill the content panel to print.
