2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-10-30T18:34:28+00:00
    Ben,
    I have the Surface Hardware Update – 10/23/2015 installed and still run into the same issue with the display driver crashing. Seems to only happen while using the edge browser.
    2015-10-30T22:44:03+00:00
    I have same issue and can confirm it occurs when using either Edge or Firefox. And I too have the Surface Hardware Update installed.
