2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-18T06:22:26+00:00
    I'm excited to hear about the Surface Pro 4 updates, but am skeptical about loading it up so close to its release date. Purchased this "mid-sized" until for my artist daughter to use and she says it's slower than her IPhone5, (which doesn't overheat, crash and/or lock up every hour.)
    Unfortunately, I let my return time allowance pass, so either we have a $1400 paperweight, or I try to sell it for probably half what was paid for it.
    I will watch for reviews after the updates have been out for a few weeks.
    2016-02-18T06:30:06+00:00
    For the past few weeks my Surface Pro 4 had been pretty stable...  Very few graphics driver crashes.  Not 10 minutes after I installed the latest updates (2/17) the GRAPHICS DRIVER CRASHED TWICE.  Why can't Microsoft ever get anything right??  This update has apparently made the issue worse. Anybody who's Surface is working well DO NOT install the most recent updates.
    I would like to offer the opposite experience: it went very well!
    Well, I needed to restart 3 times to get all the drivers and updates installed, but that's fine. The only issue was that I needed to force restart once (by pressing the power button and holding it until the power went off completely). Then everything went smoothly. I'm not getting any graphics card crashes and sleep went perfectly. I tried it last night, before going to bed I had 78% battery and I woke up this morning with 77%, 6 hours later. My device is stock, meaning it doesn't have any regedits or anything like that since I had just reformatted it the previous morning and hadn't got around to changing anything. Well, the 77% dropped to 76% very quickly. But still, over 6 hours it only dropped 1-2%.
    Thank you MS for making my device more stable and now more enjoyable since I don't have to worry about being stuck to a wall or carrying around my charger because I sleep it or shut it down. Keep the fantastic updates coming :D
