2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-16T20:33:28+00:00
    This happens to me quite often as well. However, I've noticed that it happens most frequently when I'm using Firefox. Other browsers have this error occur but much less. Don't know if this will help your issue, but feel free to try it out.
    2016-02-17T01:55:06+00:00
    Hi
    I had the display driver stopped responding issue as well but since the update my Surface 4 Pro would randomly just go dark.  I have some backlighting in the screen but no response.  only way to fix this seems to hold down the power button for 30 seconds and restart
    this is annoying!  I use this for work
    Gerhard
