2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-16T17:46:29+00:00
    Hi - I love my SP4 and don't want to be without it, but I've only had this SP4 for two days and I'm getting hourly messages that the display driver has failed and successfully recovered.
    Should I wait for a new update or simply swap out for a new unit?
    How involved is installing the latest driver from intel?
    Many thanks in advance.
    2016-02-16T20:29:40+00:00
    If you swap out u will probably end up with a refurb.  Whether it will be a refurb or new it will still have the same display driver issue.
    Is it difficult to install?  Like beauty, it's in the eye of the beholder.  Here is a THREAD with good install instructions on page 42.  I would go for the newer beta version.
    Any problems post back here for help.
