2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-14T22:34:37+00:00
    Is anyone still having this issue with the latest beta video drivers from Intel? I am planning on installing later today for other reasons, but was wondering if maybe this too was resolved.
    2016-02-16T08:08:51+00:00
    I bought my SP4 two weeks ago. I get the display driver crash especially when I play video's. Sometimes, the SP4 freezes completely, I can't even recover and have to power it down the hard way.
    I am an IT person, so because of the crashes, I tried another video player (Media Player Classic HC). It has the same crashes. Seems there is a fault in the driver concerning playback of video's. Most people here report having it in Edge & IE. As lots of websites have animations and embedded video's these days, maybe you should look into that.
    I have had other issues too (on screen keyboard not showing up, sound popping, applications having trouble with the default scaling/resolution, ...). And like a lot of people in here, I am disappointed. This device cost me a lot of money and I thought the possibilities would justify this (it is indeed a real PC where other tablets are just "play stations"), but I would have expected it to be fully tested and problem free.
    Note: I have all the latest updates.
