2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-13T15:57:39+00:00
    I have only had my Surface Pro 4 for one week but the screen often goes blank and will not wake up for many minutes. Today the screen has blanked several times and I get the error message that tells me there was a problem with the screen driver and it has recovered. On the point of returning the unit.  Given that Microsoft now decides when to change/update my system is there anything to do to improve the situation or is screen blanking a fact of life?
    2016-02-13T17:04:04+00:00
    Thanks! I checked and I have several MTConfig errors since I started today morning. And 262 of them in the last 7 days! Any thoughts how I can overcome the issue?
    Appreciate your help!
    regards,
    Vinay
    Unfortunately no. Not at this time.
    I just expect Microsoft is seriously looking at this issue.
    The MTConfig error seems to be a good starting point. My stable SP4 doesn't have it. The one affected does.
