2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-13T03:29:52+00:00
    Well - I can report that on the plain vanilla Microsoft version, it is still not fixed. I hadn't had a crash in a couple of months, but since the 2/10 updates I have had 3 of the standard Display Driver crashes - one of them so bad that I had to use the 2-button restart to get the machine going again - which happened after a day of using Photoshop on the SP4 - no Dock, no external monitors. It appeared to recover automatically, but was running poorly and when I tried to reboot the SP4, it shut down and wouldn't come back up.  Looks like we're doing the 2 steps forward / 1 step back thing now.
    2016-02-13T15:45:31+00:00
    I tried the  Windows update troubleshooter with no effect.
    it didn't show any issue with my display driver.
    I'm not sure is it device issue or driver issue?
