2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-11T13:23:32+00:00
    when i changed MICROSOFT edge with chrome I didnt have any display driver crash and work fine for me.
    2016-02-12T13:43:08+00:00
    Intel Beta Driver 4380 has so far stopped the graphics crashes I was experiencing on my Surface Pro 4 i7 512GB, so far so good. I use a new type docking station with a 32" 4K display (DisplayPort) and it was really bad previously!
