2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-11T02:09:06+00:00
    That's unfortunate. Although it has only been one day since I put 4380 in my SP4 i7 16m 256ssd, it is running great. At this point very happy, have had no crashes yet and wakes from sleep quickly every time. The real test is when I need it to work to take a note or to present something. In the past failed me almost every time when I was showing somebody or really needed it for a note or to fulfill a request now. Now turns to later or never when you cant get your PC to work.
    2016-02-11T04:54:48+00:00
    4380 works for me too!  i7 16MB + GPU.  No crashes.  Switches  Could this have solved the issue?
    I use an external monitor via the DP port.  Switching between external to on-board monitor was an issue before (crashes, could not re-recognize external monitor when re-plugging, needing reboots).  This is now solved.
    Remaining issue: when switching between external to on-board monitor, some apps appear to have really small fonts.  No way to reset that without a reboot.
