2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-10T10:16:57+00:00
    Have you tried the Windows update troubleshooter yet?
    2016-02-10T17:36:17+00:00
    4380 caused more random crashing on my M3.
    Rolled back to 4352 which is working better for my use.
