2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-10T01:50:57+00:00
    I purchased my SP4 i7 last week, and encountered the black screen issue regularly (during the normal operation, not wake up from sleep).  I installed the latest beta driver from intel (now my 540 driver version is 4380),  but it does not help. and it turned out it's related to the power management.
    If I plus my power on, the issue is gone. but if I un-plus my power, then if I pressed the windows button several times, the screen will get black.
    it's pretty annoying!
    and if I disable the intel driver and use "Microsoft basic graph driver" instead, the issue is also gone.
    so it's definitely an issue related to Intel's graph card, driver and some strange power management!
    Microsoft, please FIX it!
    2016-02-10T07:15:25+00:00
    4352 was marginally better if at all than the previous ones for my setup.
    the beta 4380 immediately showed a better performance "displaydriverwise" ( 900% less crashing ) fwiw.
    I also have the dock and the MS keyboard but i havent tested with those yet that is still to follow up on.
    For the moment it has re above only been tested without the dock so i cant comment on the useability on dock/display/ethernet. The PSU used for last nite driver tests was the same configuration as the other drivers were tested under = using keyboard and the mini accompanying PSU.
