2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-09T22:48:18+00:00
    1.  but spending days on every single version since the first one.
    i work in a very specific tech branch as an it specialist and potentially the sp4 could bring us a whole new market due to mainly its screen features.
    thus testing the 4380 is prompting me to being able to see a huge step forward and hope for us to possible buy many many sp4's now .. well soon once we reach version +4390 maybe 4400 😀
    2016-02-09T23:21:16+00:00
    I am interested in what configuration you use the sp4.  If you use the docking station with or without external monitors and if u use the rj45 network connector.  I ask this because i have an i7, 16, 512 with the sp4 docking station which I use only for power and usb connectivity.  My i7 was the first batch released on 11/19 in the US.  I have not had one display driver crash since I installed 4352 a few days after it's release in December  In addition, black screen problems after waking from sleep also all but disappeared when I installed 4352.
