2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-09T22:23:51+00:00
    the intel beta 4380 massively improved my sp4
    errorrate is now 2 crashes in 10 hours -  i would have had 20+ else.
    SP4 i7 16gb 256ssd Windows 10Pro + Ent doing max insider builds.
    2016-02-09T22:34:15+00:00
    What version of the display driver were you using prior to installation of this beta?
