2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-09T17:03:52+00:00
    I just bought a new surface pro 4.   I liked it for about a week.  Now the graphics driver crashes constantly.   This makes me close down everything and slows down my work.
    Wow what a waste of $1200 bucks.
    2016-02-09T18:47:54+00:00
    Are you asking for assistance or just stating your opinion?
