2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-08T19:57:41+00:00
    The screen wake-up issue seems to be a common problem. One SP4 in my household has the issue regularly. The other one got it only once since acquisition last November.
    Can you check your event viewer in the "System" section for an error with "MTConfig" around the time you got the issue? I think it could be the culprit.
    2016-02-08T20:10:20+00:00
    Thanks! I checked and I have several MTConfig errors since I started today morning. And 262 of them in the last 7 days! Any thoughts how I can overcome the issue?
    Appreciate your help!
    regards,
    Vinay
