2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-02-03T21:39:19+00:00
    Even with the new download, my Surface Pro 4 display driver crashes every few minutes while running my work-related software.  Didn't happen on my surface pro 3; very irritating.  Took one Surface Pro 4 back because it was doing it, but the replacement one does the same thing.  Slows me down at work, but I think I'm stuck with it.
    2016-02-03T22:23:49+00:00
    Have you tried the newest display driver from Intel? Here!  My sp4 display driver never crashes now! Can't guarantee it will help you but it certainly wont hurt to try.
    Installation instructions are on page 42 of this  thread.
