2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-29T08:43:55+00:00
    New Intel drivers  01/28/2016
    https://downloadcenter.intel.com/product/88345/Intel-HD-Graphics-530-for-6th-Generation-Intel-Core-Processors
    But from what I can see, only the date changes
    2016-01-29T13:11:54+00:00
    A new firmware was released, but did not include the new display adapter. Is this a joke?
    January 2016 updates
    The following update will be listed as “System Firmware Update – 1/27/2016” when you view your update history.
    Note
    When Surface updates are provided via the Windows Update service, they are delivered in stages to Surface customers. As a result, not every Surface will receive the update at the same time, but the update will be delivered to all devices. If you have not received the update then please manually check Windows Update later.
    • Surface Embedded Controller Firmware (v103.899.256.0) adds battery charging enhancements and thermal tuning.
    • Surface Fingerprint Sensor driver update (v2.2.10.6) improves accuracy.
    • Wireless Network Controller and Bluetooth driver update (v15.68.9037.59) improves access point compatibility and throughput on 5Ghz networks."
