2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-26T12:56:58+00:00
    same problem over here with my SP4 PRO and W10
    • display adapter crashes
    • display stays black after closing the lid and reopen it (battery saver, not hibernation)
    this makes the SP4 extremly not usable!
    i will sure not buy another SP if this wont get fixed soon
    i think i should not have replaced my old sp3, this was running just perfect
    2016-01-29T06:39:34+00:00
    We have released a new driver today, 12/2/15.
    For those that are seeing the following issue, this new driver will improve the situation.
    Display appears to hang, and then you will get a message that the display adapter has reset.  Usually happens in certain scrolling situations on web pages.
    Version info as follows...
    (v20.19.15.4326)
    Moderator Edit:
    For details on the update please view What was in the 12/2/2015 update?
    I've been having this problem with my Surface Pro 4 constantly. Scrolling facebook, watching youtube etc.
    Sometimes it's the display adapter has reset  message, other times there's no warning and the system just freezes forcing me to have to manually power off / power back on.
    I've checked for video driver updates but it's up to date and I have that exact 20.19.15.4326 version.
    The adapter has reset message I can handle but the system freeze drives me crazy. For a Surface that's just over a month old, this is becoming very annoying. Any other recommendations?
    Thank you,
    Simon
