2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-24T21:05:22+00:00
    Failed display driver is a common problem.  Some sp4s have this occur every day. There are other things that can be done to fix the problem but since ur problem appears to occur so infrequently that going thru the effort of applying a potential fix such as installing the latest display driver directly from Intel isn't worth it.  Microsoft will eventually release this driver and it will install automatically.  If this problem worsens you can always search this forum for full instructions on how to install the intel driver.
    2016-01-25T03:28:10+00:00
    I've been getting the same graphics adapter crash since I bought my Surface Pro 4 on launch day. I've searched the threads and there doesn't seem to be a solution...just wait for Microsoft to get their act together and release a fix.
