2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-22T12:37:49+00:00
    I bought this Surface Pro 4 yesterday, I've been using it just fine all day.
    However it occasionally comes up with the error message for the display driver (I can't remember exactly what it says), it does this when I am just using the internet, there's no other programs open, and only a few tabs, the sites have a few images on them but I definitely would expect it to perform better and not crash with a few pictures!!
    Is there anything I can do/could this be a fault with this device/is this just normal!?
    2016-01-24T18:49:38+00:00
    Its funny, I am searching for fixes, and all your answers seem to be shut down and restart.  every thing hold the power button 30 seconds!!!
