2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2016-01-20T21:35:05+00:00
    1. OS issues: Edge browser is a system resource hog and huge drain on the battery, especially when opening sites with multimedia content.  This causes the system fan to run at full speed.  Closing the culprit tab is sometimes difficult and the tab title will just flash at you.  Hitting the back arrow to exit the page before closing the tab tends to help.  Be sure to close Edge before entering sleep/hibernate mode.
    Same issue.
    Yes, Edge is central problem. Crash All time on OneDrive.live > pictures.
    2016-01-22T04:10:09+00:00
    I got the Surface 4 just recently, already with Windows 10 (Jan 2016) - got the display driver error that said "Windows 8 driver". I had not run updates yet, so the update (presumably from 12/2015) fixed it.  I left on automatic updates - after a recent one ran, I'm getting the craching again. At least this time, it just said "Windows" driver and not "Windows 8".
    Is another update coming soon? Other than getting this display driver crash every 5-10 minutes, it's great.
